If you refer to uTorrent, then the 170k file you download is the executable itself. There is no installer.Oracle said:If you dont need to install it as you say, do you download the standalone?
Kainz said:If you refer to uTorrent, then the 170k file you download is the executable itself. There is no installer.
Yup, I dont see why not at all. No idea why the installer version is larger unless it contains the language packs.Oracle said:ahh, but there is a 597kb installation program, but you're saying all i need is the 170kb file and I can shove that on my USB drive and run it on any machine etc?
Kainz said:Yup, I dont see why not at all. No idea why the installer version is larger unless it contains the language packs.
mrk said:Do you uguys not use *** speed guide feature in utorrent? set it to 1 level down form your up speed and BAM.
I get full speed downloads, often use 2 torrents at a time at 15k/s up each getting 150k/s+ each downspeed.
