So after a couple of days with the M440i I’ve now handed it back and picked up my X3M after it had some warranty work done. Just thought I’d share my feelings on the car having had it on my drive for a couple of days and used it as I would any car.
Let’s get the main point of contention out of the way, the front end, grills, nostrils whatever you want to call them. With this car, in Dravit Grey and with the Shadowline pack installed I must say I think that it looks very good. The number plate in the middle breaks up the shape entirely and in reality, it’s a total non-issue and no different to the similar sized grill on the Audi range and as per usual has been blow utterly out of proportion by the internet. I don’t believe the shape photographs well but given a choice I’d be more than happy to have a 4 Series, or the M3/4 sat on my drive.
Onto how it drives and what it’s like to live with. The engine is a very very good, but I suspect we all knew that, with plenty of shove from very low down up through the rev range. The gear box is calibrated to perfections as is BMWs norm, but one thing that I noticed was how quiet it was. Even when pushing on it’s a relatively quiet place to be, at motorways speeds its virtually silent, and even when push it’s not very shouty. The S58 in my X3M is a totally different beast, it feels similar in torque figures when low down in the rev range but comes alive about 2,500 rpm, where the B58 is very linear across the range. If you leave the gearbox to do its thing in either car, you’re unlikely to ever find yourself short on performance when you want it. Fuel economy is pretty good given what the car has power wise and I managed 39mpg from home back to the dealer compared to 31mpg in the X3M doing the same journey when I dropped my car off. One thing I did notice was the coasting which worked well with the mild hybrid system, quite often the car would shut off while slowing etc but restarted instantly when you re-applied the throttle.
Steering and suspension are well calibrated, even on a car running 20” wheels all round. In comfort and adaptive the ride is very compliant, but the car never feels wallowy, and is softer sprung than mine in comfort mode. Sport and Sport+ add weight and control to the already well controlled body roll, but I didn’t feel the need to go near those options often sticking to adaptive most of the time.
The interior on this car was in the Oyster and Black which looks good and the improvement on the dashboard and build over the previous generate are both well documented and pretty obvious when you get it the car. Space wise it’d carry 4 people quite comfortably assuming they are not all 6 foot+ and has a decent sized boot, with split folding seats.
This car came with Technology Plus package which includes things like the HUD, Driver Assistance Pro and Parking Pro packs. It has the full active cruise package and self-steering which I tried on the M1 and worked pretty well and if you were expecting to do a lot of motorway or similar type driving, I can see it making a lot of difference to your journeys. I think there is a reasonable amount of tailoring you can do to the settings so you have a fair number of options over what you can let the car do. The parking plus packaging with all the cameras works very well, as it has done for a long time, and I miss only having the rear camera on my car. It also has the Driver Recorder option which lets you capture footage from all the cameras around the car, but I didn’t get much chance to play with that.
The ID7 and dash I believe are a slightly newer hardware version than what my X3M runs, but generally performed the same. There are a lot of options for configuring the dash but I suspect most people would find what they like, in my case, Speedo, Rev counter and a sat nav guidance and rarely ever change it. The HUD and CarPlay worked identically to my car and did exactly what I expected. Wireless charging is a nice option and my phone lived on the pad, much as it does in my car, or stays in my pocket on shorter journeys as wireless CarPlay means it just works with no cables etc.
Overall, I liked the car a lot and wouldn’t be upset with it or the similar M340i as a long-term ownership prospect. Running costs would be pretty good and it has all the performance you’d ever really need.
