1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Build a bridge and get over it
Discussion in 'General Discussion' started by Zip, 7 Apr 2007.
  1. Le_Petit_Lapin
    Capodecina
    build an upper supporting arch from the lower yellow points, that rises over the deck.
    8 is utterly confusing btw....are you supposed to drop it or something?
    Edit:YAY got it!
  2. oddjob62
    Sgarrista
    Damn i can't believe how complicated some of your Lv7s are... did mine on a budget of 8700
  3. Luke284
    Wise Guy
    you got a screenshot of level5? i still cant get it to work... gettting closer though i think :confused:
  4. Royality
    Mobster
    I can't do Level 2 on New.... help!
  5. Luke284
    Wise Guy
    i just built 2 layers of rectangles crossed linked on the diagonal... hope that explains it well enough
  6. Le_Petit_Lapin
    Capodecina
    sure, Level 5 - new?
    [​IMG]
    Level 9 is awful, looks so easy....isnt. :(
  7. Solari
    PermaBanned
    On the old maps pack, I complete map 6 but can't get on to 7? What's going on? :S
    EDIT: works now for some reason :p
  8. Zefan
    Don
    Is the "next level" bit just not appearing?
  9. Solari
    PermaBanned
    Level 7 was easy... career change coming up maybe? :p
    [​IMG]
    8...
    [​IMG]
  10. MagSafe
    Wise Guy
    lol, just watched a video of some footage of that and it definetly looks addictive :eek:
  11. Kerplunk
    Sgarrista
    Hang about, I just spent the best part of all day doing this, Just rebooted and its all been wiped!!??!!?
    Wtf!!! :mad:
  12. Zefan
    Don
    Just redid my messy one to try yours out and mine worked better :p
    Was really messy and random though :o
  13. dsb
    Wise Guy
    how do get it to go up hill? level 6 new, done all the old levels exsept 15 for the same issue.
  14. boYce
    Hitman
    doh! how have i been playing this for 2 hours straight now!
    anyway made it to level 15, but dont get the up hill bit.
    only thing i can think of is to design it so it breaks at the right time which sometimes gives the train a little lift???
  15. Le_Petit_Lapin
    Capodecina
    Make a Flat bridge, Put a lot of weight off the ground on one end, then when you test it, it falls to the left, makes a ramp, and the train goes up and jumps the gap. :D
  16. BoomAM
    Capodecina
    Had another go this morning.
    Just one level 11 old.
    Stuck. :(
    Ideas?
  17. Zip
    Capodecina
    I got a Total Weight of 450,000 Across the bridge i built in Level 1 :D :cool:
  18. Luke284
    Wise Guy
    level 8 new anyone?
  19. Le_Petit_Lapin
    Capodecina
    Ignore the anchor point. Build a line out from it then delete it. ;)
  20. Luke284
    Wise Guy
    ive been trying that, but the bridge always breaks when it falls into place...
