1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Burstcoin - worth mining?
Discussion in 'Crypto Currency & Mining' started by Bluecube, 8 Jun 2017.
  1. EssexBoy
    Wise Guy
    Anyone still mining?
  2. postmanfw
    Mobster
    Still at it yes :)
  3. EssexBoy
    Wise Guy
    Time to move to Chia ;)
  4. postmanfw
    Mobster
    Will look into in thanks :)
    Edit : couple of quick questions....can it be mined along side other coins...is replot needed?
  5. EssexBoy
    Wise Guy
    Replot and only chia is mineable and it takes a long time to plot.
  6. postmanfw
    Mobster
    The imineblocks guy on youtube says 6hrs for a 100Gb plot if you use an ssd but nearer 20Hrs if mechanical...thats about 73 plots per 8Tb drive...1460 hrs 2 months.....will be 2 years till i am plotted lol....multiple computers required
    Also each 100Gb plot uses about 1.5Tb of writes...thats a lot of wear on the ssd so will be using mechanical for sure.
    thanks for the heads up though...you did the same with BHD...which i would have done well with if i had sold when it was £40 a coin lol....
  7. TNA
    Capodecina
    He waited two weeks after mainnet launched to mention it. He has been active in the chia community for months and got plotting done and ready for mainnet :p
  8. EssexBoy
    Wise Guy
    And who are you on there then?
  9. TNA
    Capodecina
    Heh. I only popped in once to see what’s what some months ago. Anyone can join the discord channel would see your posts ;)
