Hi,
I normally try and follow instructions on stuff like this to the letter, but the instructions are more or less non existent so I had to make an educated guess on where certain things would go.
My major concern is the main mounting screws. I took a guess that the plastic spacers are to insulate, then I used 5 of the spring loaded screws as highlighted in red:
Is this correct before I fill this with water?
Bonus question (not too worried about this). I reused the original backplate and used the long very wide headed Phillips head screws to mount it. They just seemed to fit too perfect for that not to be the correct thing to do. That won't cause issues will it?
