1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Caliper brake to V brake compatibility
Discussion in 'Sports Arena' started by Jonny69, 30 May 2010.
  1. Jonny69
    Man of Honour
    I'm looking to get some new brake levers. Problem being my bike and setup is old so I'm worried about compatibility of parts.
    Currently got a vintage Shimano Exage caliper brake set with aero levers on narrow alloy drop bars. Will newer aero levers for V brakes be compatible with this or is the movement different? I haven't measured the diameter of the bars but I'm guessing this hasn't changed?
    I'm hoping a classic Shimano SLR aero set will work, but recommendations for anything lighter will be lapped up :)
  2. Jonny69
    Man of Honour
  3. Big Chris
    From what I remember, v-brake levers (as you've said) pull more cable than standard canti/caliper brake levers.
    I think in which case you'll be fine with them. You'd only have a problem if you were trying to pull a v-brake with a standard lever.
  4. touch
    Capodecina
    A bit further down on that link you posted he says:
    So it's probably not a good idea.
  5. Jonny69
    Man of Honour
    Yeah, that's what I thought, cheers :)
