Cam belt gone on 96 1.4 litre Escort :(
Permabanned
15 Aug 2003
Ipswich
Hi,
As title really. Darn thing went today. What's the chances of me getting away with no further damage on a 1996 1.4 Escort (petrol)?
18 Oct 2002
If its mashed the valves (almost certainly has) I'd think it would be cheaper to source another CVH than repair the old one?
13 Mar 2004
well it all depends whether it is a non-interface engine. some ford perv will let you know
what were you doing at the time? idle, high speed etc
could just take the plugs out n look. a new head may be cheap, but you may also need new pistons, rods etc etc
18 Oct 2002
small chance it would be ok, if you feel inclined, stick another belt on and see what happens. If you're going to have it rebuilt you will need a new belt anyway.
18 Oct 2002
Devon
Always worth putting a belt on and trying if the engine is likely to be scrapped otherwise. A compression test will show up any slightly bent valves, (either that or the misfire at idle :D)
29 Sep 2003
As others have said, stick a belt on and try it.
A couple of years ago i picked up a Rover 827 (V6) on which the cam belt had snapped in a few places.
I put a new belt on and it ran fine :eek:
It was an auto which no doubt saved all of the 24 valves. :D
3 Jun 2005
West Sussex
If it has knacked the valves then I would look at getting a replacement engine. I have heard it loads of times and it has also happened to me that you repair the top end and the bottom end goes a little later. Only repair and sell.
Permabanned
OP
15 Aug 2003
Ipswich
Scuzi said:
That's the EFi engine, I had the same one in my '98 Escort when I had it. That's about all I know though, sorry I can't be of any more help.
Thanks though. The fact that it's not a CVH engine gives me a little more hope.
