Ohhh thank you, then this is becoming harder and harder for me.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-233-GI
If you look at this it says: "Expasion slots: 2x PCIe 2.0 x16 Slot & 2x PCI Slot (Supports ATI CrossFireX Technology)"
What does that mean?
This board may have 2 physical x16 slots (ie. they are both big), but only the 1st one can run at x16 speed - the second is electronically only running at x4 speed. Here is the gigabyte spec sheet which confirms this. Hence it isn't very good if you want to run crossfire in the future.
As mentioned before, to buy a proper x8x8 s1156 motherboard you will have to shell out at least £130.
