Can someone help advise me install and sync my RGB components?
12 May 2020
Hi everyone.
I'm currently building a desktop using a combination of Asus and Gigabyte AORUS hardware and I have a couple of questions regarding which connectors to use and to which header (4 pin Aura or 3 pin addressable) and how to sync them all using both Aura sync and RGB Fusion 2 software.
I will list the build components below:
Lean Li
Asus Rog Strix X570-F (x2 Aura 4pin headers and 2x addressable headers)
AMD Ryzen 9 3900x
AORUS AIO liquid cooler 360 (RGB Fusion 2)
16 Gig 4000mhz Team Force Extreme RGB RAM (Fusion 2 RGB and Aura Sync compatible)
500 Gig Team Force Extreme Delta SSD (RGB Fusion 2 and Aura Sync compatible)
AORUS GeForce RTX 2070 SUPER (RGB Fusion 2)
x3 TT Riing pure 12 RGB fans (RGB Fusion 2 and Aura Sync compatible)
Okay so my first question is, will I be able to set up two synced LED groups using both RGB Fusion 2 and Aura Sync software?
Second question is, what pin header should I plug the fans into the mobo, 4 or 3 (4 pin Aura RGB header or 3 pin addressable) if I want to sync them using RGB Fusion 2, not Aura Sync?
Am I correct thinking there is no way of syncing them all together?
The idea to this solve is to create 2 synced groups.
1) Aura sync group using motherboard to sync the ram and SSD
2) RGB Fusion 2 group syncing the AIO, the GPU and the 3 TT fans.
Will all the components be detected by the appropriate RGB sync software? And is there any tips or advice on how to install the components using the appropriate pin connectors?
Any advice would be greatly appreciated, thank you.
