1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Car making a ticking noise?
Discussion in 'Motors' started by EdGey, 18 Apr 2010.
  1. EdGey
    Sgarrista
    Hey guys.
    Ever since i got it, my car has made a ticking noise when i accelerate. Its more noticeable when the engine is cold, but even when its warm u can still hear it clearly. The more i put my foot down the faster the ticking gets.
    It annoys me and doesn't sound healthy at all.
    Anyone have any ideas what this could be? anything to worry about? :confused:
    Its a MK5 fiesta zetec.
  2. ganesh
    Wise Guy
    I'm pretty sure someone has put a bomb in your car, probably set to go off at a certain speed. If you're still driving now you probably shouldn't stop, give me an hour and i'll arrange mass, that'll fix things.
  3. Peerzy
    It's not a clock is it?
  4. ganesh
    Wise Guy
    Don't be ridiculous.
  5. Hades
    Caporegime
    A loud watch then?
  6. BigglesPiP
    Capodecina
    As you accelerate suggests a big end had failed, which means it will eventually seize then cease.
    However it could just be a tappet, your description is a little ambiguous. A rattly tappet is a happy tappet, in that it won't cause further damage. Tappets can be cheap to rectify too, dependant on the engine.
    So you need to decide which it is 1st. Do you only notice it under acceleration? Which engine is it?
  7. InvaderGIR
    Capodecina
    Could even be an HT lead that's duff and arcing off something like the bonnet. Lack of description on the 'ticky' noise isn't helpful. :p
  8. NeverWinter
    My first thought was a tappet.
  9. agw_01
    Capodecina
    May also be the exhaust manifold gasket.
  10. SB118
    Sgarrista
    It's the end of the cable tie on the inner CV joint slapping against the gearbox.
    Really need a better description mate ;)
  11. Janesy B
    Caporegime
    Checked the oil? This is the noise a Zetec-SE makes when it doesn't have oil ;)
  12. typk
    Hitman
    I am having the exact same problem with my saxo vtr. Its really hard to explain but it has made my engine sound a little like a diesel, it is a sort of ticking when under acceleration and a lot more noticeable when cold. I will try and get a recording of it.
    Maybe we are sharing a similar problem.
  13. InvaderGIR
    Capodecina
    Sounds like low/no oil to be honest.
    My sister's 106 1.1 sounds like a diesel due to having been run low on oil for some time.
  14. fonzee
    tappets should be self adjusting on these iirc, therefore check the oil levels (on a flat when cold).
  15. typk
    Hitman
    I have checked the oil and it seems fine, just under the maximum level. Could it be because the oil is old?
    Should I just give it a little top up? I dont want to put too much in though.
  16. Lopéz
    Man of Honour
    I'd never describe a big end knock as "ticking" but you never know.
    Really need a significantly better description or a recording of what it sounds like.
  17. Matt82
    Capodecina
    yup, me too.
    whats the oil level/quality like?
  18. Zip
    Capodecina
    My Subaru used to do this and It was just the tappets.
  19. ZG002
    Capodecina
    More than likely a tappet problem imo, If the big end was knocking you wouldn't describe it as a tick surely? It is clearly a knock lol
  20. InvaderGIR
    Capodecina
    If it's been run dry/very low before, oil change won't make much difference...which is why my sister's sounds like a dagdag and smokes like a train too. :/
    Oil change could lessen the noise I guess, not really something I've experienced to be honest. I'm going to get sister to sell hers and buy something decent. :p
