1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Car parked on dropped kerb
Discussion in 'Motors' started by beachBOYken, 27 Dec 2018.
  1. Gaygle
    Capodecina
    https://www.askthe.police.uk/content/Q440.htm
    Police won't tow the car away because they have no right to. They will only tow the car away if it's obstructing the highway, not private land.
    They can attempt to make enquiries as to who the owner is, but believe it or not, there isn't a specialspec list of phones numbers they can use. All they use is the phone book and if there is no number listed - not much else can be done!
  2. Dis86
    Suspended
    If it's preventing someone reaching the road it is obstructing the highway.
  3. paradigm
    Caporegime
    This was how I understand it. If you are impeding someone’s access to the road then it is an offence. If however the driveway was empty then it would only be causing an inconvenience accessing private land, and as such wouldn’t be the same offence.
  4. Dis86
    Suspended
    Precisely.
  5. Swifty55
    It’s an offence if you block a drive with someone already on it that prevents them accessing the road.
    It is not an offence to block an empty driveway that prevents someone accessing private land.
    That’s how I’ve always understood it.
  6. Sindri
    Hitman
    Drag/push it so it is blocking the road. Police will move it in no time. May end up getting towed, so hopefully they will get charged for keeping the vehicle in a lock up too.
  7. Nasher
    Capodecina
    It's an offense to park over a dropped curb and block access no matter what afaik, it doesn't matter if a driveway is empty or occupied. But they will only act if someone reports it (and take forever to do anything).
    Your still better off calling a mate and dragging the car down the street. Problem immediately solved. It won't damage it (probably), only confuse the owner.
  8. Shimmyhill
    Mobster
    I love how someone has taken the time to link to the answer and yet after it people are speculating what the Police should do! Police have very limited powers to tow a car unless it’s causing an obstruction on the highway, not to the highway or an inconvenience - councils deal with parking offences as a rule and will ticket for a while and can eventually remove under abandoned car powers
  9. Firestar_3x
    Caporegime
    OP do you live near an airport, could the car be from one of these scam type parking services?
  10. Iamzod
    Mobster
    Trolley jack under the rear diff, shove the back end around 90 degrees, it's now blocking the road & is causing an obstruction.
  11. Nasher
    Capodecina
    Yea you can move a car around quite easily with a trolley jack. Might be hard on rough tarmac though.
  12. snapdragon69
    Hitman
    Parking is decriminalised in pretty much all suburbs and cities. This means it has nothing to do with the Police and is the Local Authority and their byelaws and penalties which matter and they vary from Authority to Authority.
  13. Dis86
    Suspended
    Obstructing a public highway is still a criminal offence.
  14. snapdragon69
    Hitman
    In my opinion, this is not relevant to this case as there is no "wilful"... "obstruction of free passage along the highway" - personally, I can't see this applying to crossing the footpath - I mean have you met our Police these days? Very odd bunch mostly indoors looking for mean online comments and posting bizarre photo tweets. I watched a bit of body cam cops the other days, the short blonde woman actually flailed around giggling and doing a dance at the scene of an attempted murder when a sensior officer congratulated her of her first murder arrest - weirdos!
  15. Shimmyhill
    Mobster
    Parking on a dropped curb isn’t an obstruction of the highway - the closest you can get is obstructing the path so double buggies/wheelchairs can not use them as the path is technically part of the highway and even that’s discretionary under Police powers.
    You’re making the common mistake of thinking nuisance parking falls under Police powers that relate to wilful/actual obstruction of the highway.
  16. Dis86
    Suspended
    I'll explain again...
    Yes it is. If a car is on the driveway beyond the dropped kerb then you are preventing them from reaching the highway. It is a criminal offence. Which is exactly the case in the OP.
  17. Vanquish-Storm
    Mobster
  18. Dis86
    Suspended
  19. robj20
    Capodecina
    Get someone to park so close to the front and back of the car they can't move when they get back.
  20. Vanquish-Storm
    Mobster
    Why do I? Is this new act only for certain areas?
