1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Cleaning the rear windscreen
Discussion in 'Motors' started by D_Brasted, 10 Jul 2006.
  1. D_Brasted
    Gangster
    Hi,
    Does anyone have any tips for cleaning the rear windscreen (inside) of a car without wrecking the heating wires?
    Thanks.
    Regards, Dominic
  2. Dup
    Capodecina
    Windolene and kitchen towel. Spray on, clean with kitchen towel and then wipe again with dry towel to polish it up. I do the outside of mine too.
  3. William
    Capodecina
    Heating wires are pretty tough, some window cleaner and a cloth and you should be ok; just don't clean the rear window with an ice scraper or a brillo pad or somthing...
  4. Simian
    Sgarrista
    Just remember to wipe in the direction of the wires!... not up and down accross em!...
    Just in case you a bit heavy handed!.. ;)
  5. D_Brasted
    Gangster
    Thanks for the replies, much appreciated. :)
