1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Confused, Please Help
Discussion in 'Networks & Internet Connectivity' started by JoshSaville, 14 Aug 2006.
  1. JoshSaville
    PermaBanned
    Hey guys, gonna cut to the point :p
    Previously our house had 5 pcs....Now my dads GF moved in and she has 3 kids, i was set the task to build three. Which of course i did (gotpayed which helped), now this is where the problem is. All 3 work completely fine... but on one of them i couldnt :
    1) activate windows using the internet
    2) play online games (tried the sims)
    3) use any kind of msn messenger
    Now the interent works fine, i can recieve windows updates etc....
    Im completely clueless in what it could be. Any ideas? Im on 10mb NTL and Two of the pcs run of a switch, one of which works, and one which cant access msn etc..
    Many Thanks in Advance...
    Josh
  2. shine
    Mobster
    Are you getting any errors?
  3. JoshSaville
    PermaBanned
    from msn do u mean?
  4. shine
    Mobster
    from any of the apps that you've tried to access the net with but can't.
  5. JoshSaville
    PermaBanned
    no everything works fine apart from msn and using online games such as the sims :S
  6. michellez
    Gangster
    Firewall (Windows Firewall?) turned on? Try turning it off.
    What error does MSN give you for example when it doesn't connect?
