1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Control Of 3 PC's With 1 Keyboard/Mouse/Monitor ?
Discussion in 'General Hardware' started by Bint Box, 9 Mar 2010.
  1. Bint Box
    Hitman
    Hi,
    Will the USB hub option of some monitors allow control of three PC's using one mouse, one keyboard and one monitor (subject to monitor having 3 PC inputs such as HDMI, DVI, VGA) ?
    If this is possible what connectivity do I need from the PC's to the USB hub of the monitor ?
    Thx for any help
    Binty
  2. atmax1
    Wise Guy
    ant you better with a kvm switch? and I don't think it would work
  3. Bint Box
    Hitman
    OK, after a quick "google" a KVM switch seems a reasonable option.
    I need to connect 2 DVI and 1 VGA or possibly 3 DVI PC outputs to a KVM including audio, any recommendations for a good 4 port KVM that will allow this. Also, possibly one of the PC's will be running linux if thats a factor. The mouse and keyboard are USB and all PC's have USB ports available.
    Thx
    Binty
  4. shadowake
    Hitman
    Will remote desktop not work? (its no good for gaming etc) if not as sugested KVM :)
  5. cmndr_andi
    Capodecina
    This may be of use if you don't want to spend any money, you just need to be able to plug 3 PCs into 1 monitor (not all can).
