Hi
Thanks for the reply Barry,I had the pump pluged in to the pwr fan header not to happy it broke as it was doping a good job cooling my CPU at 3.8ghz and my CPU is broke as well, comp keeps getting blue screen now so well gutted. Sent it back to were I got it can't say the name of store on here is there anything you can do as the cooler was of a good standerd. Thanks for your time mate.Hi Stanton - this is Barry w/ CoolIT. Did you submit an RMA request w OCUK or w/ us directly?
Can you please tell me how you had that pump plugged in? The pump is 12v only so if you had it on a regulated fan header it could have damaged it. It may be that you had it plugged in correctly and it just died.. somtimes that happens w/ any mechanical components but we have many 10's thousands of those pumps in the field w/ well below a 2% failure rate so I just want to make sure we find the cause of the failure.
Regards,
Barry
