Corsair H100 + Scythe Slip stream Fans
14 Jun 2009
I recently upgraded the fans on my Corsair H100 to a set of Scythe 120mm Slip Stream 12mm thick fans to give a bit more clearance between the motherboard and the cooler.
The problem I am having is that the fans will both spin upon start up but then one of the fans will stop spinning and gradually start spinning again then stop, this process continuously repeats itself (it's like the fan is struggling to start).
Does anyone know why this is happening? Any other normal size 120mm fans are fine.
