1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Corsair H50 fit in a Coolermaster Blackwidow case?
Discussion in 'Overclocking & Cooling' started by smr, 20 Apr 2010.
  1. smr
    Sgarrista
    Hi,
    I have one of these ancient cases... circa 2003... wondering if the h50 would fit as I wish to buy one.
    Thanks.
    [​IMG]
  2. MouthBoy
    Mobster
    Is there any 120mm fan positions? If not, would you be ok with the H50 rad being outside the case? Also, how much kit have you got to go into the case already?
  3. Mr Gimp
    Mobster
    You need a Lian Li adaptor with a 120mm fan mount on for the optical drive bays and it'll fit just fine. I saw someone on here do it not long ago :)
  4. smr
    Sgarrista
    The case is only going to be temporary anyway so would I be ok putting the rad outside of it ? I wasn't aware one was able to do this...
