1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Corsair HX 850 Fan noise
Discussion in 'General Hardware' started by Combat Fighter, 15 May 2010.
  1. Combat Fighter
    Had my psu about a month now and have to say its the noisiest thing in my case.
    Just wondering if anyone else is having the same problem?
  2. BigBruiserAl
    Mobster
    Funny enough i was just reading over at XS how many people are saying the same thing mate. Pop over there must be about 5 people on the same page
  3. OLDPHART
    Using HX850 here bog quiet, under all condition's, case(see sig) is right next to me, loudest thing in my case is my DVD-RW when it spin's up.
  4. Marine Iguana
    Don't know mine is on can't hear it :)
  5. Combat Fighter
    Think I'm gonna rma. Cant believe the fan should be this loud.
  6. WILD9
    Wise Guy
    Mine Isn't loud at all.
  7. OpenToSuggestions
    Capodecina
    I have the 750w version and it is completely silent.
  8. Biffa
    Man of Honour
    Main differences would be the OP has a 5970 which is probably pushing the PSU harder hence causing it to load the fan up.
    To the OP is it blowing really hot air out or is it just noisy but cool air?
  9. Simon42
    Hitman
    My HX 850 is also really quiet. If it wasn't for my PC working I wouldn't know its on.
  10. el Kuarlos
    Hitman
    Mine is noisy. My HX 750 fan is spinning pretty fast, its taking in a lot of air and the stuff coming out is really cold. Its not an issue of load either, my rig isnt exactly power hungry.
    EDIT; noise is the psu fan. Did several startups, and started to note psu noise kicking in usually on moving into windows noise in bios was fine. After 30 seconds or so fan seems to throttle up, restored bios defaults. same issue, troubleshot it and I am left at;
    a. bad fan makes noise once it has warmed up.
    b. stock component/setting in system causing psu to think it is under load.
    I tend to b. my crosshair 3 doesnt seem to be too fond of the 965, chip was released after board, doesnt seem to be specifically catered to, might be a bios issue.
  11. Bremmy
    My HX850 is whisper-quiet even with the system at full pelt. Definitely no issues with a 965BE and Crosshair III (v1105 bios)
  12. Fatboyuk2
    Gangster
    My HX1000 is whisper-quiet
  13. setter
    Caporegime
    Hx 850 here, and it's very quiet, powering an i7 at 4ghz with sli gtx 275 gpu's.
  14. Monster ninja
    Hitman
    my hx850 makes no noise at all
  15. Marine-RX179
    Capodecina
    May be it's hit or miss whether the PSU fan is quiet or noisy, just like how people getting same model case fans some getting quiet one and some get noisy one may be...
  16. Speed
    Sgarrista
    The problem is noise is subjective, it also depends on what other noise sources people have. If it is really an issue, sell it and get something else. Some Corsair PSUs I've had have been loud, it all depends on the load and the model.
  17. Kelt
    Capodecina
    Location: With the færies wearing black cherries for rings
    Sounds dodgy. I have a Cooler Master Modular 850W and to hear it I would literally have to take the side of my case off, and stick my lug-hole physically onto the PSU.
