Have 4Gb installed(2XGb) on a Gigabyte GA-990FXA-UD3.
With ram timings set to auto it shows the Trfc setting on tw ram slots as 160ns and on the other two slots it shows Trfc as 60ns.
Problem is due to the slots on the 990 boards being reversed and in this order,
nearest cpu is ddr3 slot 4, then ddr3 slot2, then ddr3 slot3 then ddr3 slot 1.
For two sticks of ram as dual channel you use either slot 1 and 2 or slot 3 and 4 but i cannot tell what slots are what in bios
