1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
couple of questions urgent please as I'm loosing my rag with it!
Discussion in 'Graphics Cards' started by Bad Ass, 9 Jul 2006.
  1. Bad Ass
    Gangster
    ok,
    I've bought a DVI to HDMI cable, to run between my pc and my pioneer pdp436xde. picture is running at 720p (even though the plasma shows 750p).
    now i have 2 questions. 1, I know the 436xde CAN support 1080p, now my graphics card is a radeon x800 XT platinum can i and if so how do i get my pc to output 1080p.
    question 2, The ratio is buggered, I've tried everything, changing the ratio on the tv, playing about with the resolutions on the computer and still I can't get it right. any ideas I have about a 1inch border all the way around my plasma?
    also if anyone knows, my sound card is just a sound blaster Live! 5.1 it has a mini jack digital output, obviously on my amp I'd go in optically. however I'm having troubles getting sound. any clues on to how i sort out this problem? I'm using a cable that will do this but I still am not getting any sound what so ever?
    cheers, Martyn
  2. Coolasmoo
    Mobster
    Have you enabled the HD options in Catalyst Control Center ?
  3. Bad Ass
    Gangster
    In the FPD properties I've put force 720p mode.....
  4. Bad Ass
    Gangster
    anyone?
  5. Bad Ass
    Gangster
    someone must be able to help me with my problems???>.......
  6. Bad Ass
    Gangster
    is there anyone who can help me at all?
  7. Coolasmoo
    Mobster
    If you have no luck here, then try over at www.rage3d.com and make a post in there forums.
    Its more ATi over there than anything else ;)
