1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
CPU Fan Error beep on Asus P5W DH
Discussion in 'Motherboards' started by Pulsedriver, 15 Aug 2006.
  1. Pulsedriver
    Mobster
    Hi folks,
    Any idea why this happens every time I restart or turn on my PC?
    Three or four fast beeps followed by a 'CPU FAN ERROR' press F1 to resume.
    The CPU fan is not the standard one, it's an Arctic Cooler 7 Pro, it runs at about 910rpm according to PC Probe 2, CPU temp always around 25-26 degrees.
    Is there a setting I need to change?
  2. Psypher5
    Sgarrista
    the bios will warn if under a certain temp or under 1200rpm? Just change it in hardwar/fan settings.
  3. khushy
    Hitman
    all you need to do . . .
    is set to IGNORE that fan in the BIOS!!!
    Khushy
  4. Xez
    Wise Guy
    Yep go to hardware moniter and disable all Q-fans and ignore the cpu speed. Or go into the boot area i think and choose to disable F1 on an error
