css ping help
6 Oct 2005
Ok, this is not for me, its for a friend.
hes on 2mb adsl wirless router
He is gettin pings of 200+ from servers and constantly getting kicked for it
his steam connection settings are set correctly as i made him check that
and he is still getting the problem even if he disabels his firewall
The thing is though, when he is on ventrilo with me his ventrilo ping is fine, usually about 50-70 ping
So its obvious that its the program...
he isnt running any download programs or msn etc in the background, and hasnt got any viruses/spyware...
i cant see why this is happening to be honest, ive looked on google etc but cant seem to find a solution...
Anyone got any info?
Imy
Imy
21 Nov 2005
Warwickshire, UK
But does his ventrilo ping remain constant and low when he joins a busy cs:s server? He would probably have to launch cs:s in a window to check properly.
OP
6 Oct 2005
well im not sure, but i no hes not lagging on vent when ingame as he recives my voice in good time, not say, 5 secconds after i say it (which happens when you lag on ventrilo)
