1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Datawrite Titanium 16x speed problem
Discussion in 'Optical Storage & Writing' started by Chong Warrior, 15 Feb 2006.
  1. Chong Warrior
    Capodecina
    This is the first time I've ever had a problem with media, I'm baffled by the fact my drive, an NEC2500A, won't even acknowledge there's a disc in the drive!
    The only time it will is with some software I don't think I can name on here, it tells me the Dye is MCC 03RG20. I've now tried numerous burning programs and none will even see that there's a disc there :(
    I've tried 3 new firmwares, including Herrie's 1.07, 1.07b and a new one called 1.08 3-2.
    I've burnt hundreds of problem free disc's, the last batch I had were MCC 02RG20 coded and they worked perfectly. Anyone else tried these?
    They're sold on this site aswell but I didn't get mine from here.
  2. Rambaud
    Wise Guy
    I assume it works with other media?
    If so, it seems likely to be a firmware issue - it is an old drive. :)
    I have a BenQ 1640 which does not recognise some new media at the moment e.g. 8x DVD+RW.
    Does your NEC 2500 write at 16x, as it a 4x drive? Perhaps with hacked firmware?
