1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
DDR2 mushkin Vs ALL ? help please
Discussion in 'Memory' started by R B Customs, 23 Jan 2006.
  1. R B Customs
    Mobster
    man... im still ... STILL on the quest for RAM, ive never spent this much time buying components in my life.
    my budget just went up from 70 to 129 ( sounds better than 130 lol )
    i was gonna get 1gb 1stick of OCZ value Pro 667 Mhz
    1 module as i hasd the intent of upgrading to dual channel 2gb anyway
    now ive been looking at mushkin 2gb dual channel kits, 667 mhz.
    now i was under the impression that mushkin was about as good as it got, and i was suprised when i found i could get a 2gb kit for under 130 quid.
    i was also under the impression that is like, highly overclockable too, am i right ?
    look at the bottom 3 on this page :http://www.mushkin.com/doc/products/memory/enhanced_performance.asp
    the kit im thinking of getting is the 3rd from bottom
    how does this compare to other 2gb kits for around 130 quid ( thtas if ther is any !! ) im not an overclocker ( although i wouldnt mind looking into it ) so will the difference between them just be very very minimal ?
    cheers
    one last thing, any compatibility issues with mushkin, its an asus p5nd2-sli board, the rest of my spec is in my sig
  2. R B Customs
    Mobster
    *coughbumpcough*
