Caporegime
Here is a link to the monitor on Dell website for those of you who do not know much about this monitor.
Thus far I am very satisfied with it. I have used my Spyder tool to calibrate the screen which helped, as it seemed like there is a small yellow tint by default. Calibrated the colours look even better.
I am contemplating on whether to leave it on 100% scaling in windows (8.1) as when I go to 150% scaling which makes everything the right size but as a result things seem a little less sharp. My eyes are surprisingly adjusting to this scaling. Maybe would be perfect on say a 32" monitor.
I have had a brief go on a bunch of games in my steam library and taken snapshots which you can see in their full glory which I have wrapped in the spoiler box.
Here are some results from benchmarks/fraps.
Recent games will definitely require lowing settings to get playable frames with a 7970. But I do not want to upgrade until 20/16nm card comes out which will likely be double the performance of the 7970.
In my opinion though there are many slightly older titles which get a new lease of life you plan on replaying them. Like Half Life 2 looked very good.
Overall very happy with my purchase. 4K monitor check, IPS check, 60Hz check, SST check, Dell next day swap out if something goes wrong, check...
Tomb Raider
Borderlands 2
Crysis
GRID 2
Mortal Kombat Komplete Edition
Portal 2
Borderlands 2
Crysis
GRID 2
Portal 2
Grid 2 – Benchmark Maxed No AA = 42FPS
Crysis - Maxed No AA = 23-30FPS
CSS: GO - Maxed = 90-120FPS
Mortal Kombat Komplete Edition – Maxed = 60FPS (Seems capped)
Injustice: Gods Among Us Ultimate Edition – Maxed = 60FPS (Seems capped)
Portal 2 – Maxed = 70FPS (Minimum, usually 3 figures)
Sins of a Solar Empire: Rebellion - Maxed = 60FPS (Seems capped)
Half Life 2 – Maxed = 80FPS (Minimum, majority is 200+)
StarCraft Wings of Liberty – Maxed = 55FPS (Minimum, mostly 60s)
Sleeping Dogs [FONT="]Benchmark [/FONT]- Maxed, AA on Normal = 44.8FPS
Sleeping Dogs [FONT="]Benchmark [/FONT]- Maxed = 10.5FPS lol.
Tomb Raider [FONT="]Benchmark [/FONT]– Maxed, No AA, TressFX off = 24.8FPS
Tomb Raider [FONT="]Benchmark [/FONT]– Maxed = 13.6FPS
