Jokester said:Do Conroes have the ability to throttle like P4s?
Jokester
If you mean with speedstep then yes
Jokester
raja said:looks like the reports Iheard of this board are true, even with 0707 bios around 375fsb is the max. Certainly the CPU is capable of more, this E6600 is capable of 3.85. So i'm limited by the fsb of the board atm.
Still 3385 is not too shabby.
will run 3dmark05 next..
Devious said:What did you do to get your G.Skill over 320 FSB ?
Devious said:If you mean with speedstep then yes
trojan698 said:Throttling is when clockspeed is reduced in order to lower CPU temps to prevent damage to the CPU. Speedstep is implemented when the CPU is idle right?
Jimi said:Where's everyone getting these Core 2 Duo's from, they're not even out yet are they?
silversurfer said:No need to turn off throttling because it should never get that high. Is the 61c on the NB because of a passive heatsink?
It'll be funny if gigabyte turns out to be the best Both their boards have the best cooling on the NB and SB, coincidence?
