dfi lp ultra d s939 question
12 Apr 2006
Leeds/Northampton
On the board there is a 4 pin power connection described as 5v/12v FFD-type. What is this? I don't have an appropriate adapter. It's not the Molex connector or the square 12v one.
Its near the PCi-e connectors and the CPU. If I have to buy a special adapter, I am killing the next person I see. BE WARNED.
EDIT: Oh floppy disk drive, I do have that adapter. But why does it want me to plug that in there?
24 Feb 2003
Stourport-On-Severn
Yes, you do plug the floppy drive power connector in to it. It isn't just for SLI though. It also provides more power to the M/B and in particular to the power delivery circuits. If you are going to clock the board, then you will need the floppy connector plugged in. It will give you both a higher and more stable clock.
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
Well i don't use it on my X48 and my rig is perfectly stable at 4.5Ghz. It states in the manual that it's only needed if using more than one graphics card.
