I've run Millers Eco Max and AR6400D and BG244. In summary here's what I've observed:
Car is a 55 plate RAV4 D4D with about 112k on it, FSH but one injector while in Toyota spec, is slightly off compared to the others, occasional hesitance in re-spoiling turbo (suspected carbon build up on variable vane mechanism, only does it when going up hill and changing gear so vanes go from one extreme to another).
BG244: Added this first when car was at 96k, it had a number of service items due at 100k and I figured i'd run a fuel system cleaner through before I changed the fuel filter and did everything else. Car achieved the best mpg i'd logged at the time on that tank (37.53), engine was quieter and that was it. I paid £22.95 for a less agricultural sounding diesel for 400 miles. For comparison Shell V Power gives similar results.
AR6400D: It was suggested that I should have probably gone with something specifically for the injector/turbo side, it would be likely to improve the variable vane issues, so I purchased two bottles on offer, followed the instructions and got bugger all improvement, mpg went down (likely to do with the time of year/temps). Either way no mirracle. I shoved the other bottle through a few months later with similar results.
I've also tried back to back tanks of premium fuel from BP/Shell and Millers Eco Boost added to normal fuel, mpg was slightly better than standard fuel without it, but nothing significant.
I'd just about resigned myself to splitting the turbo one weekend and doing the job properly, when Costco opened up locally selling 'Premium' diesel for less than the supermarket fuel. After a tank I noticed I hadn't had any issues with turbo spool, I put it down to placebo/luck/forgetting it had happened and refilled again at Costco. Two more tanks of Costco's finest later and still no issue, MPG has hit previously unknown levels (so's the temperature in the last week which will have helped), but it's consistently returning higher (calculated) mpg than previous tanks. Either way it's doing better than standard and costing less, what's not to like?
