1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
DRIVER_IRQL_NOT_LESS_THAN_EQUAL
Discussion in 'General Hardware' started by owon, 23 Jul 2006.
  1. owon
    Just had system built everything running smoothly exept every once in a while I get the blue screen of death with this message DRIVER_IRQL_NOT_LESS_THAN_EQUAL anyone know what I can do 2 fix this problem.
  2. sugoi
    Gangster
    it maybe incompatible drivers, you get a lot of results if you paste that into g00gle... try this link on Microsoft Support Page
  3. MAllen
    Wise Guy
    Far too many things that can cause that. Assuming you havn't changed any drivers or hardware lately it is worth getting a copy of memtst32 and checking your memory is still good. (A quick test is to pull one of the sticks out)
  4. dafloppyone
    Wise Guy
    I get that because of my hercules digifire
  5. sanofi
    Wise Guy
    Is there a specific driver that it points to, ususally shown at the end of the message.
  6. owon
    Already done the memtst32 test everything came back fine get this message at end
    Stop 0x000000D1 (0x0003002C, 0x00000002, 0x00000000, 0xB6B4D1B6)
    NVT.Sys- Adress B6B4D1B6 base at B6B49000, Datestamp 4253b85b
  7. owon
    Also checked Application error logs all the errors at the time of blue screen point 2 ForceWare Intelligent Application.
  8. MAllen
    Wise Guy
    Just out of curiosity, I Googled NVT.sys and got this clue for you...
    Try uninstalling or updating the nvidia firewall. Are you behind a router? If yes, you can do without the nvidia firewall. I removed this from a mates computer when he was complaining about bad CS:S pings and we saw a noticable improvment.
    :D :cool:
  9. cobxx
    Gangster
    I had this problem a few times. Happened whenever I was using limewire or bit torrent, and was sourcing the netgear wireless driver dll. Stopped using the automatic configuration software crap and all working fine now.
  10. owon
    Already tried removing forceware installed windows firewall instead still have same problem Iam using a router dose router act as firewall
  11. Stupido
    Gangster
    i had this problem with a pc i built for a relative.
    this problem drove me to despair. Ive never had a problem with any pc that i built and the 2 that i built after the problem one were fine !
    did all the tests on memory,drivers,mobo,psu,video card etc. But the thing still displayed that message and randomly BSOD.
    Did 4 rebuilds and reinstalls to clean formatted HD - still had problems.
    eventually i found a webpage suggesting that it could be a problem to do with windows update installing the wrong drivers.Looking at the error log and then checking what the error realted file did further confirmed this.Seems that some file that was being added during automatic updates was the cause.
    so for rebuild number 5 i decided not to run automatic updates .
    This fixed it .So i guess in this case it was a driver issue and something to do with windows update.
    hope this helps
