Dual, Dual or Dual Dual???
20 Feb 2009
Hello
So, I've been thinking about getting a new graphics card or 2.
What exactly are the advantages and disadvantages of these 3 different configurations:
ATI Radeon HD 4870 X2
or
2x ATI Radeon HD 4870's (with crossfire)
or
2x ATI Radeon HD 4870 X2 (with crossfire)
I'd guess the 3rd option would be the best, but are there any disadvantages of this dual dual type setup?
Any answers are much appreciated,
Thanks
28 Nov 2008
Power consumption
Noise
Poor scaling (compared to x2 or x3)
Expensive
Heat
It will be an amazingly fast PC though, and Crysis will be playable on maximum settings and AA, which is nice.
7 Jul 2007
Hello
or
or
Thanks
Would 2x 4780 x2 work on a 32bit pc? They both have 2GB of ram each, so how would all of this be adressed?
You might be forced to use an x64 OS
2 Nov 2006
Sheffield
The amount of memory XP32 loses is not a straight calculation of gfx card memory +250mb.
Aparently its possible to get 3.75gb out of it with a 1gb gfx card, if you turn off everything but the kitchen sink in the bios.
