1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dual layer burning help.
Discussion in 'Optical Storage & Writing' started by yfas29, 5 Jan 2008.
  1. yfas29
    Hi all,
    wonder if anyone can help. i've been trying for days to burn a 6.4GB file to a dual layer disk using nero 8. half way through the burn i get an error message saying bur failed. I have since downloaded Imgburn to try and burn said file, however during burn I get an error message saying burn failed with this info
    W 19:16:06 Retrying (4 of 20)...
    W 19:16:06 Retry Failed - Invalid Address For Write
    W 19:16:06 Retrying (5 of 20)...
    W 19:16:06 Retrying (6 of 20)...
    W 19:16:06 Retrying (7 of 20)...
    W 19:16:06 Retrying (8 of 20)...
    W 19:16:06 Retrying (9 of 20)...
    W 19:16:06 Retrying (10 of 20)...
    W 19:16:06 Retrying (11 of 20)...
    W 19:16:06 Retrying (12 of 20)...
    W 19:16:06 Retrying (13 of 20)...
    W 19:16:06 Retrying (14 of 20)...
    W 19:16:06 Retrying (15 of 20)...
    W 19:16:06 Retrying (16 of 20)...
    W 19:16:06 Retrying (17 of 20)...
    W 19:16:06 Retrying (18 of 20)...
    W 19:16:06 Retrying (19 of 20)...
    W 19:16:06 Retrying (20 of 20)...
    W 19:18:18 Retrying (21)...
    W 19:18:18 Retry Failed - Invalid Address For Write
    W 19:18:19 Retrying (22)...
    W 19:18:19 Retry Failed - Invalid Address For Write
    W 19:18:20 Retrying (23)...
    W 19:18:20 Retry Failed - Invalid Address For Write
    W 19:18:21 Retrying (24)...
    W 19:18:21 Retry Failed - Invalid Address For Write
    W 19:18:33 Retrying (25)...
    W 19:18:33 Retry Failed - Invalid Address For Write
    W 19:18:35 Retrying (26)...
    W 19:18:35 Retry Failed - Invalid Address For Write
    W 19:18:35 Retrying (27)...
    E 19:18:36 Failed to Write Sectors 1852112 - 1852143 - Unknown (Internal Target Failure) (0x44, 0x86)
    I 19:18:37 Synchronising Cache...
    I 19:18:38 Closing Track...
    I 19:18:43 Finalising Disc...
    W 19:19:29 Potential 'WaitImmediateIO' Deferred Error - (0/2) - Unknown (Internal Target Failure) (0x44, 0x86)
    E 19:19:58 Finalise Disc Failed! - Reason: Unknown (Internal Target Failure) (0x44, 0x86)
    I 19:19:58 Finalising Disc (Last Attempt!)...
    E 19:19:58 Failed to Write Image!
    E 19:19:58 Operation Failed! - Duration: 00:23:26
    I 19:19:58 Average Write Rate: 2,871 KB/s (2.1x) - Maximum Write Rate: 3,360 KB/s (2.4x)
    I am using a LG Dvd DL rewriter model 4167B with the latest firmware and infiniti DL disks. Anyone have any ideas what the problem may be. I have a liteon DL writer in my HTPC but dont know how to copy the file across to try burning on that.
    Any help much appreciated.
    Cheers
    Andy
    PS Any ideas as to why XP device manager is showing my IDE optical drives as SCSI drives?
  2. jeffa123
    Hitman
    Don't forget you are using ISO 9660 +joliet which only caters for files up to 2GB per file transfer. This is why you are getting errors. If you were to look at movies on dvd even they are limited to this file structure. The only time you can use files larger than 2GB on DVD writing in nero especially, is if you were to write in UDF format.
    I hope this helps. If not google a dvd authoring site and see for yourself.
  3. helmutcheese
    PermaBanned
    Burnt over 150 DVD9's in Nero 6/7/8 and never had 1 coaster.
    I did not set any special settings either and it was simply a DVD-ROM I was burning, also backed up my Games to DVD9 with Alcohol.
  4. jbloggs
    I see you have the Gigabyte P965 DS4 mobo, I assume that is using the Gigabyte SATA (jmicron) cont. (and your optical devices are attached to that)...if you have it set to run in AHCI mode (with the drivers installed) the optical devices will show up in Device Manager as SCSI drives.
    Instead of using infiniti DL disks, try another brand/dye, Verbatim Datalife Plus that uses the MKM 001 dye. :)
  5. rubberduck
    Mobster
    FYI, I had problems burning the Infiniti (Rioch) discs you mention on my Benq 1650... They worked fine on my NEC 4550 although to be honest they are not great media.
    Generally if it is a case of your drive not liking the media, problems will occur at the layer break so check for that.
    As mentioned try a different media (Verbatims preferably). Also try burning with a different drive (it could be a bad batch of discs).
    If you just want to do a test to see if they are ok on the other drive download a copy of Nero CD/DVD speed as that can burn a test disc for you.
  6. siege2
    Wise Guy
  7. rubberduck
    Mobster
    Always remeber that with any recordable optical media that the long term stability of the dye is crucial.... Many people assume that because they have burned 100s of Brand x media without a single coaster then the media must be good quality.
    Try playing those discs in a couple of years time and see if you get any read errors!
  8. helmutcheese
    PermaBanned
    Little free tip for you, buy Verbatim Media.
  9. rubberduck
    Mobster
    I could not agree more!
