1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
Dual monitor help
Discussion in 'Graphics Cards' started by whitworth2001, 17 Mar 2015.
  1. whitworth2001
    hey guys
    am having trouble with my duel display on my graphics card.
    i have 2 monitors Viewsonic HDMI 1080p and a HP W227h i wanted to duel these to screens up but having difficulties.
    So i first plug in my Viewsonic Via HDMI to the back of my graphics card everything is fine and monitor is on,
    then i try and plug my other monitor in using HDMI to DVI-I converter.
    every time i plug this in it turns off my viewsonic monitor giving no signal untill i unplug the HP DVI-I connector.
    ive switched these around so the HP is using the HDMI port and the Viewsonic using the DVI-I port but it does exactly the same with only 1 being on at a time
    ive reinstalled windows even changed my graphics card from a GTX560TI to a Radeon R9280x but does exactly the same.
    ive had it running great for a few hours untill i restart the pc then back to its usual tricks but not getting any joy anymore
    i have also tryed to plug in my tv to it and it does the same thing
    Fx8120
    Radeon R9280x
    16GB DDR3
    asus m5a78l-m
    Any help is greatly appriciated
    Kris
  2. sneakypenguin
    Gangster
    Have you tried using a normal dvi cable on the second monitor? I've got one via hdmi and the second via dvi and no problems. Updated your graphics drivers? Could also be a faulty dvi port.
    mick
