1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
dvd drive upgrade
Discussion in 'Optical Storage & Writing' started by DarkWhisper, 12 Sep 2009.
  1. DarkWhisper
    Hitman
  2. AbsenceJam
    Mobster
    Well one writes to BD, one doesn't...
  3. DarkWhisper
    Hitman
    WHAT
  4. 5abr3
    Gangster
    The second one you linked to will burn Blu-Ray. If you are prepared to wait for new stock and aren't intending to burn data to blu-ray media any time soon I would get the cheaper (first) drive and buy a burner at a later date when the prices have dropped.
    Personally I would only get the reader not the re-write version, blu-ray discs are expensive as it is!
  5. DarkWhisper
    Hitman
    Thanks you whats the first one like as a blu-ray player
  6. K.C. Leblanc
    Sgarrista
    I'd have though the blue ray performance is more down to the power of your PC then the drive. What spec are you running?
    And bare in mind you'll need blue ray playback software.
  7. DarkWhisper
    Hitman
    Spec is as below
