1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Electricity top up
Discussion in 'General Discussion' started by willd58, 3 Aug 2006.
  1. willd58
    PermaBanned
    Hi, i have one of these instead of an electricity meter, i have no idea how it works other than i have to take the stick out and top it up at the post office down the road.
    [​IMG]
    Does anyone know how i find out how much money on the meter i have left?
  2. benjo plz.
    Capodecina
    When the light's go out, you've run out of credit :p.
  3. willd58
    PermaBanned
    Thats kinda what im trying to avoid! :D
  4. crashuk
    PermaBanned
    you see the 2 fat red wires well disconnect them and move them over to the to other guys system :D
    yer go get it topped up and just stick it in.
  5. basmic
    PermaBanned
    I can't remember, but you just tap one of the buttons - it cycles through the data as you press it.
    The other one, my favourite button - insert key, press button. On goes only a pound from whatever is on your key. If your leccy runs out overnight, no standby devices will sap away at your juice. :cool:
  6. basmic
    PermaBanned
    Just read instructions on meter. :o
    Press grey button for credit release.
    So if you get say £7 on your key, and want to use about £1 a day over the week. Just insert key, press grey button - it'll say £1. Press it again, to add another quid. However much you need to take off the key.
    I always irritated my landlord. Was a shared passageway downstairs, and I had 1st and 2nd floor (lived above a shop). Sometimes he'd want the light on in passageway - of course, my leccy runs the passageway light, and I had stuffed my key somewhere safe. :D:D:o
  7. benjo plz.
    Capodecina
    Looking at the picture, the instructions he wants don't seem to be there :p.
  8. basmic
    PermaBanned
    All he needs to do is press the blue button. It'll cycle through, and he'll eventually see his balance. Doesn't even need to shove his key in. :confused:
  9. willd58
    PermaBanned
    It cycles threw alot of numbers, but im not sure which one is my balance, im hoping its not the one thats just simply 5, cause that means i only have 5p left. :(
    i think i might go and cycle threw the whole lot, write down each one, and post them here, see if you guys can figure it out.
  10. DRZ
    The image you posted seems to have a £ sign on it...
    £2.48 perhaps?
    That image is bigger than the sun btw, so it might need resizing to one that doesnt kill children...
  11. Foehammer2003
    Hitman
    yeah i think it is a £ sign, lol but if it is it says £24201! lol guessing where the decimal point is, bit like pin the tail on the donkey
  12. willd58
    PermaBanned
    right, here goes
    on the first cycle, the first number says =E 248.01
    a press of the button changes it
    the word "rate 1" is highlighted along with "accepted" with the number -E6.16
    another press changes it to
    total charge per week = E 0.080
    then it displays 8000000 or so KWph or somthing
    then it goes to rate 2 which = 0 on every screen
    A final number is E- -E0.005
    Then it displays total debt = 0.00000
    I am completely confused, anyone got any idea's?
    Edit: im guna call my landlady's tommorow and see if they know, ill also call the electricity company, im just wondering if i can figure it out tonight.
  13. willd58
    PermaBanned
    changed it
  14. basmic
    PermaBanned
    I believe that's the total amount put on the meter, since it was installed. I could be wrong.
    That sounds like it's the total amount on your meter, after inserting the key.
    That's your supplier's rates. Are you sure the total charge per week isn't 8p/day?
    What gets me, is it isn't showing how much you have for emergency. Most key meters give you £1/£5 emergency - so if you forget to top-up your key, just bang on some emergency credit to tide you over.
    Out of interested, could you go through those readings again, with the key inserted? Possibly some photos, too?
  15. peter_hutson
    Wise Guy
    If you have any doubts over the rate you're paying for your electricity give your supplier a ring. A few years ago I got stung by one of the these meters. I moved house and found that it had a pre-pay meter. Thought nothing off it, until I realised one day that I was spending rather a lot. Gave my supplier a ring and found out that I was paying twice the market rate, as the previous owners had run up a huge bill. So they installed a pre-pay meter with and inflated rate to recover the debt over time. The gits I bought the house from never bothered to tell me, nor did the electricity company when I contacted them on moving in!
  16. dirtydog
    PermaBanned
    Ugh, I used to have one of those - bloody expensive as I recall :/ I would change to a normal meter if you can. (plus buying cards for it was a PITA)
  17. willd58
    PermaBanned
    Iv got an update on this.... :(
    Apparently the first figure is indeed my balance, and on moving in i moved into the house with a debt of 240.00 odd pounds. Iv contacted my landlady's. there guna sort it out, any idea's how i should go about this? Obv im not guna be paying it, but I also want to know how to tactifully avoid confrontation, as im not as diplomatic as some.
  18. Mr Mag00
    Hitman
    to get over this you need to get your balance above the debt of £240. when i moved in to a flat that was what i had to do then the leccy Co refunded me. This is due to the previous tennent(sp?) not informing the leccy Co that they were leaving and the weekly charge continues to build up. there is no other way around im afraid.
  19. wolvotim
    Hitman
    Connect the two outer grey cables that go into the meter together in a connector block and hey presto free leccy :p
    -----------edit----------------
    BTW don’t actually do that wouldn’t want to get anyone arrested ;)
  20. rayer
    Wise Guy
    Believe it or not, but I moved in to my house 3 weeks ago, and just found this out as well. Will they give me a refund on any of this ?
