- 21 Apr 2015
Hi Guys
I have this Mobo... https://www.overclockers.co.uk/gigabyte-b450-aorus-m-socket-am4-ddr4-matx-motherboard-mb-573-gi.html
1st...The Board has 2 system fan ports and I have 4 fans so would something like this link work or would it be better to get an adapter to run the extra 2 from the PSU?
2nd...The RGB cable for the fans is 4 socket and the board it is 5 pin (12,R,G,B,W). Previously I squeezed it on and it worked (the W pin bent slightly) but on this fan set the socket is wider and I cannot squeeze it on without potentially bending the W pin too much. What can I use to connect it, is there a 4 pin to 5 pin adapter? Am I being stupid?
Thanks all
Thanks all
