1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Fan Controller Advice
Discussion in 'General Hardware' started by BigRazer93, 19 Oct 2009.
  1. BigRazer93
    Mobster
    Hello, I'm going to purchese a fan controller which is touch screen and i have noticed there are temp probes sensors to tell you temps on where you put them. This is my first fan controller so I could do with some advice. Where do I actually put them to get a correct readings? I want 1 on the cpu and the graphic card. (4890 but getting crossfire at crimbo).
    My theoy is putting the probe on the cpu directly but how? Put thermal paste then probe then h50 or?
  2. BigRazer93
    Mobster
    Quick bump :)
    Edit* Some one gave me a bit of advice and they said "put one any where on the gpu and put one on the back of the mobo plate on the socket."
    Any more advice.?
  3. Nameless_87
    Hitman
    I'm looking to purchase one as well... Can you provide a link please?
    Thanks
  4. BigRazer93
    Mobster
    I would mate but I aint getting it from Ocuk (Sorry ocuk :( ).
    You don't have the one I want.
