I believe "Reliable" was the key word here, not broken
He also already owns a 2011 535d.
Excuse me sir, I've had ample experience of both.
Buy Broken - Keep Broke
Buy Reliable - Make Broke
Perhaps if you read things correctly you would not think this to be a joke.
No where have I expressed concern over lexus, and I have posted the c180 with the same unexpressed concern - where I hope others to express informed opinion
I'd like a car that I can trust when needed but I can also leave in a ditch if required - so spending more isn't an answer I'm afraid, I already upped from 500 to ensure a reliable purchase.
Regarding my finances - I have not had a job for over 1 year, have 2 children in nappies and a wife who doesn't work.... so no, I am not loaded but I do try to be smart with my money
Cheers Diesel over petrol in terms of reliability?MK1 Octavia 1.9TDI. Preferably 90/110HP as they are the most bulletproof, but the rest aren't far behind.
I took mine from 140K to 180K and it needed nothing bar servicing. Friend of mine has one on 430K which is still on its original turbo, injectors, etc.
The Bora and Toledo of the same era are the same car.
Failing that, something Japanese. Accord/Civic, Avensis/Corolla.
If MPG wasn't a concern but dependability was, what would your choice be?Excuse me sir, I've had ample experience of both.
Just read the OP say "MPG isnt important" so my suggestion doesn't make the same amount of sense... I thought we were talking 500 miles a day regularly.
Seen mention of an old Lexus. Yes, but for £1K, no.
OK I'm out.
OP... Leave the cheap and decent cars for those of us who need them. Drive the BMW you maniac.
Pretty much what I'm doing, and gumtree & ebay. So far a 90s citron c5 is the cream of the crop - although that mini is tempting.If it was me I would just filter Autotrader to less than a grand, petrol, manual transmission and less than 100k miles.
Something like a 2.0 Mondeo or 1.6 Focus.
Having read it again I can hold my hands up and say that I misread it. Also, I hope you find a job soon
I still think you’re better off spending more. The people you see driving around in old cars have probably owned them for ages, are driving them around on a budget or don’t do many miles. More importantly, generally, people selling cars this cheap will be doing so because something is wrong and it’s not worth repairing. Sure, this isn’t the only reason and you may get fortunate but I’d be surprised. Even at the 3-4k range I think it’ll be a case of going to look at a fair few cars to find the diamond in the rough.
I'm afraid the budget is fixed to "as low as possible" - You definitely can get a decent car for under a grand, just have to find the right seller
You'll definitely find something, people's views on here that it's impossible are bizarre.
Hmm... I'm not 100% on that. Older = simpler = less to go wrong (?)I wouldn't limit yourself to cars under 100k mileage either. I'd much rather have a newer car with more miles than something older with lower mileage.
Saab 9-5?
Cheers Acme, I don't mind an octavia, bit dull to drive but comfy. What years were those engines?I guess I'll stick to my Octavia suggestion then.
As for whether a diesel is more reliable, that will open a can of worms anywhere you ask it, including here.
In the case of an old diesel, when you intend on doing significant mileage, I'd say yes.
Oh you can also run the early 90/110 TDI's on chip fat or biodiesel if you like. They aren't PD engines.
I think the call would change depending on each specific comparison. Generally somewhere middling on both age and mileage would probably be the safest bet.
9000 or even 900?Bit complicated and expensive on the ol' parts for a cheap reliable hack I recon. Same for Volvos, as much as I like them. Both of mine needed suspension bushes/etc to eliminate knocking noises, and neither of them were anything like this cheap.
9-5s are no more complicated than any other petrol car from that era and are simpler than many. They are still port injection and don't have variable valve timing. As to running costs, I've run two 9-5s over the last 11 odd years. One purchased for £950 which lasted 3.5 years of daily use and the other was a touch more expensive at £3.5K but has lasted over 8 and is still my daily. Neither needed much beyond basic consumables other than thermostats and the odd suspension bush. Obviously your experience with running a 9-5 long term may differ from mine.
Good network of indys for servicing, plenty of second hand parts available and OEM parts are still available via Oreo.
9000 or even 900?
My 9-5 Aero just crapped cylinder 4 and is having a rebuild at 153k. I think remap had a lot to do with that. However find a standard lower spec car and you will be fine. I have had nearly 6 trouble free years however.
Didnt you have to do a significant amount of suspension work too? Subframe bushes and such?
You always used to try and talk me out of getting one.
