1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Firm Ground Football Boots
Discussion in 'Sports Arena' started by Adam, 24 Jul 2006.
  1. Adam
    Sgarrista
    Need some new boots having not played for a few years. My plan is to get some firm ground boots for around £20 and then get some Predators or F50+ when the ground gets softer. I just need to get through pre season and some tournaments without playing in trainers :p
    I have found the Nike Total 90 III for £16 which looks like a good buy. Can anyone suggest anything else?
  2. atpbx
    Capodecina
    Total 90's suck ass.
    You might as well cover your bare feet in grease and try and play.
    Mind you, they are all i ever wore on hard ground.
    Still rubbish mind.
  3. Gilly
    Man of Honour
    Yep. Total 90's suck ass. The cheapo ****bro :)p) ones I had were better
    Though for £16 you can't go wrong.
  4. Adam
    Sgarrista
    Hmmm I ordered them but might send them back straight away in that case. Not quite sure what to do for the best, I want a good quality soft ground pair of boots but can't really justify £50+ on some firm ground boots for 2/3 months maximum. Playing with blades on hard ground isn't really an option as they ruin my heels. Are they really that bad? Should I get astro turfs instead?
  5. tom26
    Hitman
    If you're getting the new F50+'s they can have both firm and soft ground studs interchangeable so why don't you buy them now and keep them for the rest of the season and save yourself £20
  6. DB_SamX
    Sgarrista
    I recently bought some cheap F10+ for £25. QUite comfy and ok for a weekly game on hard ground. They are mainly designed for astroturf though.
  7. Adam
    Sgarrista
    They are the Tunit version, I will just be going for the soft ground blades.
  8. Starzy
    Hitman
    Guys,
    What would you say is the best on-line shop to buy footie boots from? My local boot shop is now closed and places like JJB etc are just pants, after another pair of Valsport tbh.
    Cheers
    Chris
  9. BrenOS
    Mobster
    Nike Multigrounds
    Got a pair for last two months of last season, love them. May actually be my favourite boot to date :)
  10. tom26
    Hitman
  11. Gilly
    Man of Honour
  12. tom26
    Hitman
    Ye but he also sais he's buying some f50's for the softer ground when the season starts
  13. bjmerry
    Gangster
    Get yourself on ebay and buy some second hand proper moulded boots with life left in them. I recently bought a pair of second hand umbro specialis for £12. They were in amazing condition and have still got loads of life left in them. Look for boots that are not as common as Nike and Adidas and you may find yourself a bargin.
  14. Adam
    Sgarrista
    I wouldn't buy second hand boots :p
    Well they arrived today and are comfortable enough, bit plasticy but for £14 what do you expect! Only have to serve me a few pre season friendlies and a couple of tournaments so it would have been pointless spending much more.
    I tried on some Predators yesterday and found them very narrow. They will give a bit which should make them just about ok but seemed strange that they were so narrow. I by no means have wide feet :confused:
  15. Gilly
    Man of Honour
    Preds are too narrow for my feet, though I have had no trouble at all fitting trainers... well... ever.
  16. Bakedgoods
    Capodecina
    I've got to admit I was a little concerned about how tight my new predators are. I do actually really like the boot though so i'm going to try wearing them for abit and see how my feet feel.
    Guessing you've got pretty wide feet like myself Gilly? You found any boots that are pretty good for this?
  17. Gilly
    Man of Honour
    No thats what I meant by the trainer comment. I don't have wide feet at all.
    Joma are pretty good though.
  18. mrmoose
    Wise Guy
    if your going to be playing week in week out why not invest in some copa mundials and a pair of world cups, then u can live the 70's retro dream
  19. tom26
    Hitman
    If you've got wide feet I've found that the air zoom's from nike are quite good boots for them.
