1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Funky water colours,what do you add?
Discussion in 'Overclocking & Cooling' started by locutus12, 15 Jul 2006.
  1. locutus12
    PermaBanned
    someone on here made their water glow and look like a bluey purpleish plasma, any idea what id need to get that effect ? presumably UV cathodes but what would i add to the water ?
  2. aardvark
    Sgarrista
    if you want something to fluoresce blue you could add some washing powder - not sure if that might get a bit foamy though :p
  3. locutus12
    PermaBanned
    lol, maybe shove a sock in the resevoir while im at it...
  4. ichabod crane
    Man of Honour
    UV dye or buy some UV reactive tubing as UV dye clogs blocks like STORM and CASCADE cos of the tiny hole system. and tarnishes/stains tygon really quick
  5. neo-omega
    Hitman
    you COULD always try mixing food colouring?
  6. Jokester
    Don
    Using fluorescent marker pens are very effective from what I hear.
    Jokester
  7. locutus12
    PermaBanned
    now thats just a damn clever idea... im quite impressed :)
    p.s. which one of you evil don lot just nabbed 500 of my posts...
  8. aardvark
    Sgarrista
    food dyes are not fluorescent.
    and marker pens? i think youll find that most are solvent based and not water based so won't dissolve in water - you might have to shop around to find some water based ones (maybe kids pens??)
  9. Jokester
    Don
    Their solvent based so that they dry out quickly when used on paper.
    Someone tested different colours on the forum a year or two ago by basically taking the felt out and dumping it in a jar of water to let it leech out before putting it in their loop. Obviously stainage is a problem but I don't think that's any different to the proper stuff.
    Jokester
  10. Trip Hazard
    Gangster
    Or to avoid the whole furring/clogging issue you could get UV reactive tubing.
  11. locutus12
    PermaBanned
    tubings already bought im afraid.
  12. McNutter
    Hitman
    You could always pish in the water. That would turn it the "funky" colour you're looking for and it's free.
  13. Brizzles
    Sgarrista
    I used the same method for my loop.
    Soak in small amount of distilled water for 24 hours to get a nice concentrated mix.
    Then add to your loop till you get the desired effect.
    I used flourescent yellow and it worked well with cathodes.
    And from experience it didn't stain the pipes or the res.
    The UV additive i have used before turned the pipes cloudy/milky.
    Cheers,
    Mark
