1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
GA-P35-DS3 and reboot/warm boot problem
Discussion in 'Overclocking & Cooling' started by parkie, 22 Aug 2008.
  1. parkie
    Gangster
    I'm having a very annoying problem that only happens after a shutdown or a reboot. I normally run at 400x8 = 3200mhz and whats happening is sometimes after a reboot or warm boot the bios changes to 266fsb which brings the cpu speed down to 2.13ghz (8x266). from then on whatever setting I put in the bios it doesn't take and will just keep coming back at 266. I have to reset the cmos to get things back to normal again. any idea what this is about? Is this an unstable overclock or something odd going on with the bios?
    hope you can help
    p
  2. wod_uk
    Wise Guy
    are you running the latest bios as it might be worth updating it to f11 and see if that makes a difference
  3. parkie
    Gangster
    the latest for my revision is actually f13 and yes I am running it.
    cheers
    p
