1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
GeForce 1070
Discussion in 'New to PC gaming & upgrade advice' started by ROBERTO MORRIS, 18 Dec 2017.
  1. ROBERTO MORRIS
    I have the following setup and want to upgrade to 2560 x 1440 gaming - just now I only run at 1920 x 1080 on a Sapphire 11199-16-20G AMD Radeon HD 7870 Dual-X 2GB GDDR5 Graphics Card.
    I bought this bundle from OCUK in 2013:
    Quasar 215i" Intel Core i7 4770K @ 4.2GHz Overclocked Haswell Gaming PC Bundle
    MB - Gigabyte Z87-HD3
    http://www.expertreviews.co.uk/pcs/motherboards/53366/gigabyte-z87-hd3-review
    CPU - Core i7-4770K at 4.7GHz
    PSU - Corsair RM Series RM 750 '80+ Gold' 750W Power Supply (CP-9020055-UK)
    Can I add a GeForce card to this setup and a new monitor and run titles on highest settings at 2560 x 1440 resolution?
    Thank you in advance.
    Roberto
  2. Tom898
    Gangster
    Simply put, you can indeed. You should be fine as long as you don't go for a really high refresh rate monitor.
  3. ROBERTO MORRIS
    Thanks @Tom898.
    I'll starting Googling which card to buy and which monitor to pair it with.
    Roberto
  4. Rannoch
  5. lee32uk
    Underboss
    Do you want a G-Sync monitor or just a standard 60Hz one ?
  6. ROBERTO MORRIS
    @lee32uk I'm not sure - there is various differing opinions on what monitor type to go with - but I reckon G-Sync would be the preferred - what's your experience?
    Roberto
  7. Mickcas
    Gangster
    I ran a 1070 with a 1440p 144hz gsync screen. Games ran great, didn't get the full 144hz at highest settings unless playing low demanding games. But was fine either way, since upgraded to a 1080ti and even then in some games at highest settings it can't hit 144hz
  8. lee32uk
    Underboss
    I have no experience of G-Sync as I only have a 60Hz 1080p screen myself. Most people who have gone with G-Sync though say it is like night and day. Even things like moving the mouse is smoother on a high refresh rate screen. And of course if you play a lot of FPS then it is also good to have a high refresh rate and response time.
    I would say for the GPU you want a GTX 1070/ti minimum for 1440p/165Hz. Obviously if you want to push the framerates then try for a 1080 ti.
  9. ROBERTO MORRIS
