1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB640
Discussion in 'Memory' started by allllec, 13 Nov 2007.
  1. allllec
    Mobster
    Helping out a mate - selling him my rubbish ram. And like, i want to get some 800mhz stuff for a better overclock since i cant run a divider on my board.
    anyway, whats this stuff like?
    since there so similar im split between
    http://www.overclockers.co.uk/showproduct.php?prodid=MY-010-OK&groupid=701&catid=8&subcat=813
    http://www.overclockers.co.uk/showproduct.php?prodid=MY-058-GL&groupid=701&catid=8&subcat=813
    http://www.overclockers.co.uk/showproduct.php?prodid=MY-064-GL&groupid=701&catid=8&subcat=813
    if none of them overclock ill just get the ocuk stuff, but if any of of them can deffinatly get to 425mhz ill go for that kit :)
    ta
    alec
  2. allllec
    Mobster
    hmm, orrdering soon - cant believe no one has an opinion... ;)
  3. Richdog
    Caporegime
    The Ultra Low Latency is the best... the other two are more value orientated.
  4. allllec
    Mobster
    Rekon i could squeeze a small oc out of it if i needed to? litterally just like 30mhz
  5. BEn_2600+
    Hitman
    got mine to 1032MHz :D
  6. allllec
    Mobster
    Oh, well that'll do then ;) aha
    ta
    alec
  7. badgaz1
    Gangster
    What timings?
    I shoved mine straight up to 900mhz 4-4-4-12 as soon as I got them and they're stable but haven't experimented since.
  8. schumi84
    Mobster
    Good god, thought it was my RAM that was holding back the overclock as have the same GEIL stuff you have. Running at 900MHZ 5-5-5-18 so am thinking it is just my CPU that doesnt like the higher speed.
  9. DanielSon
    Gangster
    I have 2gb running at 1000, 555 15
    I run it at 2.2 volts for prime and mem-test stability.
    I have just received anther kit of GELI so now have 4gb in an abit ip35 pro.
    fun times ahead, i plan on swapping the chips to test speed and OC on the new 2 gig, then but them together for the 4 total!
    dan
  10. BEn_2600+
    Hitman
    It did those speeds at [email protected] but it was happy at 1000MHz at 5-5-5-15 @2.25v
  11. allllec
    Mobster
    omfg,
    just got home to do the order and its JUST come of this week only!
    argghhhh!!!!
    Geil value stuff it is then :(
