1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Getting Surround Sound on Media Centre
Discussion in 'Home Cinema & Hi-Fi' started by hawker1986, 15 May 2010.
  1. hawker1986
    Wise Guy
    Hi Guys,
    I was just hoping for some quick advice on a HTPC issue. Ive just sorted my cousin out with a HTPC, E5300, 4GB RAM, G33 mobo, ATI 4850. Basically im using the HDMI to connect to the TV via an adapter as both connections on the card are DVI. Sound is setup through the HDMI to the TV also, but I can only configure the device up to 2 channel, none of the other options are available.
    He has a Samsung HTZ 120 surround system and his Xbox360 + Skybox are running through the TV the same and hes getting surround sound on that.
    Any ideas how I can get surround working from the PC? (latest cat 10.4 installed btw). I cant think of anything, im running a very similar setup but direct to an AV receiver and have had no probs with it.
    Cheers guys
    Hawker
  2. Yakyb
    Gangster
