Hello guys ! First let me apologize for my ENG i will try my best.
I need help with my new gigabyte aorus xtreme 3090. My pc spec. is :
MOBO : Gigabyte gaming g1 X99
CPU : 5820 k
RAM : 16 GB corsair dominator
My pc wont post with 3090 instaled. It just keeps boot looping. Mobo stuck at B6,04 or B1 after that it turn itself off and start another loop with same results. When i insert my old 1080ti pc works fine. I know 3090 works fine. Tried it with my second pc (MSI Z77 Mpower, 3770k) it post and work without problem.
My PSU is Seasonic platinum 1000w original cables connected separatly (no diasy chain)
Things i tried so far :
- reset bios at least 5x (even took battery out)
- flashed latest motherboard bios
- switched to second bios
- changed PSU
- checked card if is fully seated in slot (i did this many time)
- checked if PCIE cables are fully connected (i did this many times)
- disconnected all USB devices
- disconected all HDD and SSD
- disconected everything except GPU
- tried different display ports on GPU
- i cant see any shorts, nothing is in contact with GPU
Im slowly running out of ideas what to try next. Take motherboard out of case and try if it boots?
Swaping GPU for my old 1080ti and pc start working without issue. Is this issue becouse of old platform? I know x99 is old, im planing upgrade in near feature. I game at 4k 60fps. I used this PC for last 5 years without problem.
Thanks you guys for reading this and for any advice.
Thomas
CPU : 5820 k
- changed PSU
Thomas
