1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Gigabyte EP45-UD3LR how to keep my q6600 constantly at 2.4 ghz ? need help plz.
Discussion in 'Motherboards' started by skywalker2204, 21 Feb 2010.
  1. skywalker2204
    Hi all,
    I recently bough a gigabyte EP45-UD3LR mobo and after installing windows Xp on it I realized that it is so slow.
    I always have to wait when I do something like open a new window in firefox or even when clicking on the start button. So i checked if everything is working at full speed and i realized that the Cpu is only runing at 1.6 ghz on idle.
    It is a Q6600 normaly working at 4 x 2.4 ghz 266mhz by 9 mult. but now it has the multi. set at 6 when idle and rise up to 9 when I luch bigger apps.
    I rised the FSB to 333 mhz and it helped a little bit but the multi stays at 6 on idle.
    I want to know if anyone can help me to find out :
    1) how to get my cpu constantly working at 266 or 333 by 9 (ingame it is stable at 333*9)
    2) if that isn't the problem, why is my pc so slow ? ( have 2x 2gb DDR 2 800 from OCZ )
    I'm sorry for my english, i never learned it at school and had to learn by myself.
    thank you for your help. i realy need it
  2. ghop
    Gangster
    Your English is very good considering you learnt it by yourself :)
    The lower speed at idle is caused by Intel Speedstep which is a technology designed to save power when running at idle. If you turn that off, you'll be running at 2.4ghz constant :) However, it shouldn't make your computer noticably slower. Download CPU-Z and check if your memory is running correctly as well.
  3. skywalker2204
    Thank you for your quick answer.
    I made some screens from cpuz so you can take a look.
    [​IMG]
    In SPD it's the same for slot 1 and 3.
    Where can i disable the Intel Speedstep ? in bios ?
    THX
  4. skywalker2204
    Speedstep is disabled in bios and in OS. now it is working fine on 333*9 canstantly but my pc is still slower than before ( with my old asus mobo with only 2gb ram ) don't understand why....
  5. Tiamat21
    Hitman
    Have you thought of Virsus, the old school problem.
    If not, try reset the bios and reformat your HDD if things are constantly slow.
    But thats just a last resort
  6. skywalker2204
    it's a brand new hdd i just installed windows yesterday so i don't think it's a virus but i check, I always put an anti-virus before conecting to internet.
