1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
GPU or Monitor
Discussion in 'Graphics Cards' started by deadeyedic30, 6 Jul 2006.
  1. deadeyedic30
    Wise Guy
    Should i get a clearance section 7800GT or save and get a
    Viewsonic VX2235wm 22" Widescreen LCD Monitor - Black (MO-060-VS) ?
    I have an FX55, Epox 9NPA+SLI, leadtek 7800GT, 2 Gb or Geil value ram and X-Fi platinum. Monitor is a Viewsonic VP171B2 :confused:
    I gam, make mp3 and surf. Games, FPS and sims.
  2. semi-pro waster
    Man of Honour
    I'd say that SLi 7800gts would be wasted on a 17" monitor but then I don't know quite how well a single 7800gt would cope with a 22" monitor at high resolutions. I'd probably buy the monitor and if necessary tone down the settings.
  3. deadeyedic30
    Wise Guy
    I've never been one for the AA AF filtering, I always start with a high res no extras then up the detail levels as i tweak it, if i find the graphics card isn't able to cope from the get go.
  4. spb251272
    Hitman
    Ideally, you'd get both at the same time, but if that's not possible, get the monitor first, then the new card as soon as possible. You can turn a few settings down in the meantime.
    Just had a look at that monitor - it looks pretty good for the price, but not available for another month :(
  5. LanceCrossfire
    Hitman
    at high resolutions you dont need as much AA anyway, so i would say the monitor and just wait for the next gen cards maybe...
  6. deadeyedic30
    Wise Guy
    Or the 1900XT/7900GTx's to come down in price a bit more. :p
    Meant to be saving for a mortgage. :confused:
