1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
Graphics Card recommendation please - £200-£250 budget
Discussion in 'Graphics Cards' started by SteveP, 2 Jun 2010.
  1. =XDC=FluphyBunny
    Mobster
    I would go for one 5850 now with a view to either crossfire in the future or whatever is out at the time. A lot of people were crossfiring the 5770's when the 5850's were in such short supply.
  2. Fatboy
    Don
    Totally agree here. I would take a 5850 now and then buy one later down the line if needed.
  3. popej
    I have a similar question if someone doesn't mind helping.
    I'm considering the same card (the one linked by #2), I'm going from a 4850 however. It's starting to chug a bit and with my system* its definitely a bottleneck.
    *(https://www.overclockers.co.uk/showproduct.php?prodid=FS-065-OE - same processor as this but bought 6 months ago)
    I have a similar budget, is the upgrade worth it?
    Ta.
  4. Fatboy
    Don
    Yes it will be worth the upgrade.
  5. Big.Wayne
    Capodecina
    Hey Steve,
    what screen res would that be then? . . . 3840x1200 or?
  6. SteveP
    Give or take, yes. It doesn't go full-screen in that mode, so it's actually a window dragged large across both monitors, so if you take a handful of pixels off the width for the window border, and a bunch more off the height for the window's title bar, and the task bar, then you are pretty much there.
    Live for Speed seems to have good multi-monitor support. You can adjust the angle of the second monitor relative to the first, and so on.
    Cheers,
    Steve.
