Old Boxters S have gone up as well though.
The standard ones are still cheap. A cheap Porsche just sounds like a huge gamble though.
Managed to get it up on ramp and get some photos!
https://ibb.co/album/C63yVk
Yea the plan is to get it under sealed now.
Products and advice appreciated!
My friend who works at the garage can get it on the ramp!
looks good m8. tbh, looks no worse than my 2012 car did when it was 4 years old...Managed to get it up on ramp and get some photos!
Woah! Never seen one get that bad!! For those sorts of problems, is the chassis rail repairable or replaceable?
There are replacements and/or strengthening solutions, but it's a lot of money to remove the engine, chop out and replace.
Just remembered I had this photo of my chassis rails...
I suppose this is what kills MX5 ownership then, I had a lot of rot on my Triumph Spitfire, I had to get rid, regret it now!
Dinitrol, Hammerite, Bilt Hamber all do decent products and places like Rejel do complete kits.
Although a local place did warn me of throwing rust proofing in to every cavity as you can block drain holes which will cause bigger headaches than leaving it with the factory underseal - not sure if this was NC specific but it's obviously worth thinking about with the drains on the NC.
That's pretty impressive Was that on a NB?
