1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Help me identify a bolt
Discussion in 'Motors' started by ScoobyDoo69, 26 Jun 2013.
  1. ScoobyDoo69
    Sgarrista
    Hi all,
    Trying to find out the size of a nut and bolt that I removed from the Peugeot yesterday.
    It is used as a pinch bolt to hold the ball joint in place to the hub. I can't seem to find a size anywhere, and ideally I need to replace this bolt asap (it has decided to thread it self on the last few turns so I can't get the nut back on.)
    Car is a Peugeot 306 diesel estate.
    Any help appreciated.
  2. Liampope
    Mobster
    Go and buy it from Peugeot.
  3. MooMoo444
    Caporegime
    Get another from a scrappy? I'd imagine the bolt used would be the same on all Peugeot cars from the period
  4. SB118
    Sgarrista
    M10x1.5x56mm
  5. jon.bda
    Mobster
  6. fonzee
    Common issue. Make sure the replacement bolt is perfectly aligned in the hub before torquing up as you can screw the hub else / create an oval shape. Resulting in a knocking ball joint that doesn't sit right.
  7. Dogbreath
    Capodecina
    OT, but why do so many people use the word "threaded" when they mean "cross threaded", or "stripped"? All bolts and screws are threaded, it's a defining feature.
  8. ScoobyDoo69
    Sgarrista
