1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Help Me!
Discussion in 'Monitors' started by Crazy Dave, 24 Jul 2006.
  1. Crazy Dave
    I am currently looking to buy a new 19" (No More) flat screen monitor that has a high resolution and bright enough for extreme gaming. my budget is £250 at the most (including VAT) so will you please make a suggestion-Thanks :D
  2. Dark_Angel
    Capodecina
    Well, 19" TFT's have the same max res as 17" TFT's (1280x1024). That is unless you want a widescreen one (1440x900 I believe).
    The Hans OCUK widescreen and the acer Wide screen around around 150 or so I believe, both being very good value for money. If you want a regular monitor though, I not so certain I only really researched about widescreens. :)
  3. wellibob
    Mobster
    If you can squeeze to a 20" widescreen 16-10 monitor, do so :D
  4. -|ScottFree|-
    Wise Guy
    High res = larger panel. You will not find a panel that display's 1600 x 1200 on a 19"
    The max you will get on a 19" is 1280 x 1024 of WS 1440 x 800.
    If you want a really good monitor for your PC then get the Acer 19" Widescreen or the Hanns WS. Both res @ 1440 x 800 the only difference being that the Hanns as DVI and VGA. I have just bought 2 Hanns WS for presents. The recipients are more than pleased with the performance, especially as they can run both there PC's and Xbox's using this monitor.
    There cheap too.. if you want higher res... look at the 20" market. There are a few available at that budget!!!
  5. hp7909
    Samsung SM-940BF 19" LCD Monitor - Silver/Black (MO-041-SA) on 'This Week' for £217.32 incl. VAT. Used this :D
  6. Dark_Angel
    Capodecina
    Are you sure that you are running in 1440x800? cause on OCuk it says it should run native at 1440x900? or did ya miss type?
  7. Crazy Dave
    thanks for all the suggestions! i will have a look at the 20" market and maybe consider raising my budget
  8. Raikiri
    Capodecina
    http://www.overclockers.co.uk/acatalog/Online_Catalogue_This_Week_Only_25.html#aMO_2d052_2dVS
    http://www.overclockers.co.uk/acatalog/20_Inch_LCD_Monitors.html#aMO_2d011_2dDE
    Or if you really don't want to spend any more but want a slightly higher res (1400x1050) and the larger screen size you could get this:
    http://www.overclockers.co.uk/acatalog/20_Inch_LCD_Monitors.html#aMO_2d061_2dVS
  9. FrankJH
    Capodecina
    there are of course "flat screen" CRT's which would enable OP to use higher res
    Dont get me wrong, I think from what he said he was after a TFT - but there are plenty of CRT's available for that budget that could do really hi res
